- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Besides the Cobra with 1.7:1 rockers, basically all Windsor smallblocks are 1.6:1 and 9:1 compression(same for the 93-95 Cobra).
From what I've read, the HO cam works great in the Explorer. I have a Mark VII LSC, and the 302 HO has a poorer low end and top end than my Mountaineer. The GT40 heads and intake bring an easy 500rpm+ in the Explorers, and that's with the "little" truck cam. I doubt there is any noticeable loss of bottom end with the HO cam. They are still small cams compared to performance cams. They all have only about .450" lift and just over 200 degrees .050 duration. My 347 has .590 lift and 219-230 degrees of duration. The cam should match the heads in some way. The stock heads, and any Ford style straight inline valve head, they are all relatively small heads. If you move up in airflow, the next heads are $1200+, but require more cam and intake. That's where the bigger power comes, then you see numbers like 300-400hp etc.
I think you will be fine with that mild 302. The computer should have no trouble with it, but a new tune would likely gain it 20hp or more. Compression is a key to power, any change can help.
