model-a
- December 29, 2008
- Escalon, CA
- 02 Ranger
I seem to be having a different problem than are discussed in the stickys.
Mine flairs up when going into 4th and won't go into 5th. OD light is blinking.
An enhanced code of P0735 which is something like 5th gear ratio is wrong.
I've done the pressure tests and nothing seems to be abnormal. The ATSG manual I have is for a 5R55E (they don't have one for the 5R44E) points toward the #1 solonoid. I'm going to try to monitor the PCM outputs to the solonoids while going through a shift sequence, before I drop the pan.
