Bizjet
- August 24, 2005
- Little Rock
- 1993 Explorer Sport 4.0
I resently bought an 2001 4x4 sport and changed all the fluid including the trans to Mobil 1. A couple weeks later I was doing some moderate (not pushing it very hard) four wheeling/mudding. When I went to put it in reverse to get turned around it tried to lunge forward when I gave it a bit of throttle. Thinking this was odd, I put in Drive, it wanted to go forward, back in R tries to go forward, shift to P, tries to go forward, N, 1, 2 same thing. I never actually drove forward in any other gear than Drive as I was afraid of doing further damage. I was able to get it home but it shifted strange, wouldn' go into 4th or 5th overdrive and OD off light flashed unless I cycled the switch. I got it home, checked the cable, fluid level and all fuses were good.
I took it to a transmission shop and they tell me the trany is shot and it gonna be $1800-$2400 to fix it. He said the clutches must be locked up/welded together and it needs a complete overhaul.
I really need some advice on this and did not find any similar cases searching on this forum.
Please Help!!
Please Help!!
