Hitchhikingmike
- January 21, 2008
- Dallas, Texas
- '02 XLS
Howdy,
Here's the situation: I've got an '02 explorer 2x4 v6 with the 5r55w auto trans in it. The truck has 43,000 miles on it. I don't know if this would be related, but I had goodyear flush the transmission and put in a new filter 3,000 miles ago. This is the first flush the transmission had. During the last 3,000 miles the transmission shifted flawlessly.
I dropped a friend off at his house after school, during which I let the explorer idle in the driveway in neutral. When I tried to leave I shifted into reverse but the truck did not engage, nor would it engage in drive or any other gear. After re-selecting drive a few more time and restarting the engine trying to get the transmission to engage, the truck finally engaged in drive, but after that it was slipping and would not shift past 1st gear.
The O/D light then started to flash in my face after 10 minutes of driving!
I tried reverse, drive and neutral and the truck went forward in all gears. I drove a short ways home at about 30mph while the shift selector was on reverse. Then I put the car in park and selected drive again, but the truck went backward in drive, neutral and reverse!
I check the shift selector cable and it is attached and calibrated to the transmission.
A day later, no matter what gear i select the truck just remains in neutral in all gears selected.
Could this be a leak in the valve body? a stuck solenoid? Broken band? Burnt clutch pack? Do you think this will call for a complete overhaul at 43,000 miles? I am the second owner and the truck has never been offroading or driven harshly.
Do you think that if I overhaul the transmission it will crap out in another 43,000 miles? According to the reports on this site, this explorer seems to have a crappy transmission.
http://www.carcomplaints.com/Ford/Explorer/2002/transmission/transmission_failure.shtml
Please help! I need this unreliable truck for school! Thank you.
