chuckhet
- October 28, 2006
- Rochester, New York
- '97 Sport 4X4
hi guys, i've been beating my head against the wall trying to figure out the problem with my explorer. it's a 97 sport with a 4.0 ohv and a 5R55E trans. i did some searching on here and found some good info but couldn't really find anything that i thought would help. when accelerating and the transmission goes to shift from 3rd to 4th it feels like it shifts to neautral and will rev up. if i let off the gas and give it a second it will shift to 4th and then everything is fine. also after start up when put into gear it will slip for a sec then slam into gear and go then be fine, it will only do this the first time taking off after start up but will slip from 3-4 every time. i have replaced the valve body with a reman and that didn't help, i pulled the trans and had it rebuilt by a trans tech at a local ford dealer and he really didn't find anything when rebuilding it. now after spending weeks and a bunch of $ it's still doing the same thing. I have checked for codes with a factory IDS scan tool and have no codes related to the trans. any ideas and help would be greatly apreaciated. thanks and please help me figure out what's wrong with this thing.
