2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
I've read that the 5R55E transmission has internal thermostatic control of the ATF temperature. When the ATF temperature exceeds a certain value the external flow to coolers is enabled. I have a remote ATF filter and two stock coolers. I bypassed the radiator mounted cooler. My remote filter never gets warm to the touch and my temperature sensor at the inlet to the filter (output of the transmission) never exceeds the minimum of my pod mounted gauge (100 degrees F). However, my data log during a WOT test recorded a max internal ATF temperature of 177 degrees F when the outside air temperature was 32 degrees F.
Has anyone monitored the PCM "transmission temperature" parameter with their scanner? If so, what temperature ranges did you observe?
