wollimann
- July 19, 2011
- Location
- Europe Germany
- Europe (Germany)
- 1997 4.0 sohc xlt
Hello,
this is the second time that i miss 1,5 liter of automatic transmission fluid. The firts time i found that missing oil
inside the transfer case. Changing the seal input ring (other two rings too) of the Borg Warner 4405 and that should
fix the problem.
For a while the problem was fixed, now (in a couple of days) the same amount of trans oil is missing.
I have to look if the transfer case oil level ist too high, but it is too cold outside to crawl under the car.
There are no other leaks of trans fluid, so i suppose it is the same issue with the seal ring.
But why does it happen? Is there a high pressure inside the extension housing which could move the oil into the transfer case?
Or is it normal that the seal fail its service?
It is a Motorcraft seal, not the one with the metal flange.
I am very annoyed of taking out the transfer case too often,
but i love my 96 Explorer 4.0 sohc and will fix it as soon as possible.
Are there any thoughts of that issue?
kind regards
Wolfgang
fix the problem.
kind regards
Wolfgang
