nathansmith50
- January 22, 2015
- grand rapids, MI
- 2014 PIU
I'm having transmission problems and I need some help.
Symptoms:
Circumstances:
Attempted repairs:
Theories:
Symptoms:
- Showing code P0755 which according to my reader is "Shift solenoid B Malfunction"
- No Drive or overdrive. Manual 1 and 2 work normally. Drive then functions for 3rd and 4th if the O/D is turned off.
- No reverse...or rather limited reverse. the truck will idle backwards but pressing the accelerator has almost no effect.
- Other codes: P1151 - Heated O2 sensor bank 2 sensor 1 indicates lean.
P0325 Knock Sensor 1 Circuit(Bank 1)This is caused by my replacement of the engine with one that doesn't feature the knock sensor bung in the oil pan. only included because i have no idea if it's relevant.
Circumstances:
- My truck lost reverse completely not long ago so i bought a parts truck that had a transmission put into it three years ago. that transmission is now in my truck.
- It worked perfectly for about a week then lost drive for 1 day. then drive strangely came back for 2 days. then lost it again.
- When it was working i got the flashing O/D light after a little driving. this problem happened in the old transmission as well so obviously there are either multiple problems or the problem is outside of the transmission.
Attempted repairs:
- I have replaced the Valve body with an updated one. though it already had an updated one in it.
- I have removed and inspected the OD servo and all is well there. i can't seem to get the intermediate servo cover off to get that servo out.
- I have replaced the bracket that holds the selector cable because the one i had was loose.
- I have tightened the bolts on the selector under the dash which were loose and doing so did allow me to get it into first which i was previously unable to do.
Theories:
- O2 sensor problem is somehow related? this seems crazy to me but i suppose is not totally impossible.
- Engine wiring harness was damaged in the engine install. this seems most likely to me. i cut part of the transmission harness to get the old engine out since i was planning to use the new harness but the new harness had different connectors for the transmission so i had to solder the old harness back together. i know the soldering, heat shrinking, and taping work was done right though i'm beginning to doubt my wire connections as there are at least three wires in that harness that are the exact same color as others.
