5r55s trans fluid check for overfill | Ford Explorer Forums
Littleant
Location
Vermont
Orleans
2010 Mountaineer 4.0
To check trans fluid it says vehicle has to be level. If the vehicle is sitting on level ground is that good enough or should it be jacked up and make sure the pan is perfectly level. Thank you
is this a question or an answer...
All i can say is change it every 30k miles.
whoops, i misread the or is it part... with that being said, as long as its on level ground, it should be close enough imo... now there may be slight differences with jacking it up and making sure its perfectly level with a gauge etc, but to me as long as the ground isnt noticably sloped, it should be fine...
It's a question
