Guk22
- September 13, 2012
- South East Mass
- 2003 Mountaineer 4.6L AWD
2003 Mountaineer V8 AWD 185K miles. Rebuilt trans about 2 1/2 years and 40K miles ago due to the dreaded flashing OD / servo bores. Truck is in pretty good shape, like to keep it going a bit longer without a huge investment.
-The problem, sometimes I get in (hot of cold) and drive anywhere... no issues, shifts perfect, no codes, leaks or other obvious problems.
-Other times I get in and it simply will not move! Doesn't matter if it is hot or cold, sitting flat, on an incline, sunny or snowing.
I have tried a fluid and filter change, no difference. The fluid and filter that came out appeared new and I'm sure this was a waste on money. The only thing I can come up with is the "Transmission Pump Flow Control Valve" may be sticking causing this. I can change this $40 part. I would rather not spend the time and effort if this is only my best guess. I am hoping to get some input from the trans experts here.
