- February 8, 2003
- Sacramento, CA 95827
- 1992 XLT
Neither does the pan.
Hi, I was reading the problems that you had, and was wondering if you could help me a bit. I recently bought a 2003 Explorer 4x4 XLT and have been having transmission issues (shifting hard, excellerating rpms). I used my scan tool and came up with 3 codes. PO732 Incorrect Gear 2 Ratio, PO735 Incorrect Gear 5 Ratio, and PO775 Pressure Control Solenoid B, I have taken it in to get estimates on it, and I know that it's the Solenoid, but since I'm a girl they keep giving me lists and lists of things wrong, when I checked it out, before and after they did, does this still sound like the problem? I cannot fix it myself, because I don't have all the tools I need.
...It is not the solenoid pack, the band or servo piston is broken. On 5R55W transmission 99% of time it is the band...
Ok, I am kind of at a cross road as what do try to do with this vehicle next. The problems with it are when it tries to upshift into 2nd or 5th gear. I have never had a problem with it downshifting.
I can turn Overdrive off, and when accelerating release the gas and it will shift into second. I drove the car for about 20 miles yesterday doing this and the O/D light never did start flashing or the PCM throw a code. However, if I keep accelerating, it will not shift into second, and around 30mph, the O/D light will start flashing.
Manual first gear does have holdback.
The solenoid pack has been replaced, and well as new fluid and filter. O/D band has been adjusted, so I know it is not broken.
It appears that is it a valve body problem, or the O/D servo is bad. Which one do you all think that it is? I am thinking if the O/D servo was bad that it would not go into 2nd gear at all?
If the valve body is the problem, what all should be replaced? the entire valve body and separator plate?
I am needing some advice and logic as to which of these is most likely the problem.
As a recap, the original symptoms of the car is that it will not upshift into 2nd or 5th gear. When the tranny fails to shift into these gears the PCM will have an error code of P0775, However, as I mentioned above, I have found that if I release the gas pedal at about 20mph the car will shift into second, and no error codes.
Thanks for all your help.
