- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
Did that place contact you at any point? I wouldn't be surprised if they didn't.
i have a 2002 xlt 4.0 v6, about 198000 miles. i have a harsh thump when put in reverse or drive, a thump when i make a quick stop and the transmission shifts down, occasional slip in first from a stop, and i have to let off the gas peddle to shift from second to third gear. no check engine light or flashing od light. i have checked the fluid level and it trickles out when the motor is running. anybody have any idea where to start?
Here's what I found. The intermediate band anchor was lying in the bottom of the pan. I can't tell if anything is wrong with the intermediate band itself. Here's a video:
http://youtu.be/L22Vt1FrCQ0
The question I ask in the video is if the anchor (if that's what it's called) can be put back in place if the band is not broken with the transmission in the vehicle? Or it is impossible that the anchor has come loose without the band breaking?
Thanks!
Well it just gets more confusing.
After verifying the linkage is fine and double checking the electrical connector, we decided to test the theory that the fluid level is just not high enough to allow shifting. (even though I followed the steps of adding 5-6qts, starting, shifting then adding more, until hot enough, then let drain until it drips, etc).
So I pumped in a couple more quarts without letting it drain, sure enough it shifted fine.
So now that this showed me it wasn't a bad solenoid, I decided to put the new solenoid back in since I already paid for it and because it's new. Followed the solenoid swap steps again. Put in all new fluid again. Waited for the stream to change to drips (which was at least 2 quarts of solid stream until the dripping), capped it. AGAIN no shifting. So pumped 2 quarts back into it and even though when I removed the hose it started a solid stream again... I didn't wait this time and just capped it. It shifts again.
So not sure what in the heck is going on. Apparently on my car, waiting until the stream slows is too low for my trans to function.
I verified I do have the standpipe. I also verified that the sump is as long on the new filter as on the old. Is there some way I could've installed the new filter too high? I made sure the old filter o-rings were removed from the hole and that the new filter had new o-rings. We are stumped.
Problem solved. First I replaced the solenoid block with the one from the original transmission. There was no change...still not shifting. Then I decided to check the fuses...The F37 fuse needed to be replaced.
Which is the f37 fuse? Thanks!
