Genci64
- September 28, 2024
- Houston, texas
- 2017, Ford explorer inter
Hi, I am posting this thread with hope to help anyone who has the same issue as i had.
I han issue with fuel pressure, code P008A, P0087.
Did a lot of research and a lot of people fixed this issue by changing the hpfp( high pressure fuel pump), so I did that. Didnt fix the issue.
Send the car to an autoservice nearby they did a diagnosis which cost me 162$ and concluded that the issue is with the fuel pump in the tank.
They said that it costs 2250$ to change both fuel pumps in the tank (parts and labor), I thought that it was too much and decided to cut a hole under the seat and try to fix it myself.
Once I replaced the main pump, I checked the codes with my OBD 2 reader and it got values of 570 kpa, which was the desired pressure, did a few tests and kept getting the same good results luckily, so I did not change the other pump (sender unit), the whole thing cost me only 320$.
280$ was the pump with lifetime warranty from oreillys.
40 $ the metal sheet and adhesive.
So far the car doesn't smell like gas nor do i hear a noises.
Ford explorer police unit 2017.
