6x8/5x7 Speakers. Best of the Best. | Page 2 | Ford Explorer Forums
expo5.0 said:
there is no replacement for surface area in car audio particularly with mids and highs (coming from someone with 26 speakers playing the mids and highs in his truck- lol)
Tyme to get sooper einstein on joo guys :D :
Surface area is VERY important if considering VOLUME OUTPUT only! STEREO signal, i.e. your cd's, FM radio, MP3's, etc., have 2, count 'em, TWO recorded channels of information. In a perfect world, two full-range (and I mean FULL range, 20-20kHz) speakers, one left and one right, would be best. Of course this is not reasonable or even possible- because of speaker characteristics, placement restrictions, and driver limitations we are forced into needing bass "in the trunk", mids at our knees, and highs aimed "wherever it sounds best". This therefore requires splitting, mixing, slicin' and dicin', and disarranging the original source signal, which remember, started as two sounds. expo5.0, I hope you have 4-ways plus 6 subs in a 5.1 channel setup, otherwise you have 13 points of origin for sound to recreate the single microphone's recorded input. It may sound LOUD and it may sound OK, I'll give you that... but where's the soundstage? In your head? :confused:
To answer the original question at hand, put a 6.5 flange over the 6x8 hole, and open up a whole new window of opportunity. Get a set of 6.5" coaxials (or braxials. Whats a braxial? www.cdtaudio.com
) or else mount a separate tweeter as close to the mid driver as possible, kicks are best for this and aiming.
:smoke:
~stu
I was told round is always better than oval, but I don't know enough about audio to know the effin' difference.
The voice coil on a 6x8 is round whereas the cone is oval. This muddies the sound as it takes longer to move certain edges of the speaker's cone. The difference in sound from round to oval is minimal. However with a 6.5" round speaker hole your options for speakers is multiplied by tenfolds. Also, abandoning the coaxial speaker setup (like 99% of 6x8s out there) makes a more noticeable improvement in sound quality than speaker shape. Other than the JL and maybe a couple others I don't know of, 6x8 speakers don't come as component sets. The JL's sound pretty good though.
~stu
That makes sense then, since the sound has farther to go on the 8" sides then the 6" sides.
Now, If you want to stick with coaxials instead of going with components, What about a coax with a crossover?
Does that make the soundstage and such noticeably better than one without?
As far as ovals are concerned, I mean.
As a point of reference, I'm thinking of getting infinity kappa 682.7cf's up front, and infinity reference 6812cf's in back.
The kappas come with a crossover I understand, sending the sound two places instead of just one?
Now will it be that much of an improvement over just having the reference series in all four doors?
And furthermore, would it be benificial (meaning, worth the money) to step up to a component system, like the infinity kappa 680.7cs for the front doors?, and then either of the two coaxials for the back.
I understand now that the round speakers would provide optimum sound, but in keeping with the subject of the thread, thats why I am using 5X7/6X8 models as examples. And also this is all just for discussion, as I am very interested in learning more and more about car audio and I'd love to hear opinions, no one has to be right, and most of us are also not competing with anyone, just wanting to please ourselves. :)
EDIT: Links to models I quoted.
http://www.cardomain.com/item/INFKAPPA6807CS
http://www.cardomain.com/item/INFKAPPA6827CF
http://www.cardomain.com/item/INFREF6812CF
EDIT number 2:
There is also an infinity reference series component system 6810cs, which I'm guessing is still better than coaxials, being that it is component, but just not as clear as the kappa components?.
http://www.cardomain.com/item/INFREF6810CS
Too many choices, not enuff speaker holes, lmfao
In my opinion, if money were no option, i'd find a good high end 3 way system. I think alpine, focal, boston all make them. And for the best imaging, i would ditch the door speakers and use kick panels. Used with a good amp, then the sound would be incredible. I probably wouldn't even use back speakers at that point and if i did, then use a 5" component set and find a way to not use the doors and image them better toward the front. :)
I'm glad to see you're putting alot of thought into what would suit you best and trying to learn more about what you're putting in your vehicle :) You've asked some good questions, I'll try to answer them all, from the top:
All coax's have a "crossover" of some type; even on cheaper coax's, you'll find an INLINE crossover. This means that the midrange driver will usually be full-range, but if you look at the positive speaker lead going to the tweeter on a coax, you'll find a little resistor that acts as a high pass filter for the tweet. It's usually a very cheap, shallow dB/octave crossover (meaning it's filtering effect is weak and will allow SOME midrange frequencies to through to the tweeter). What's important is that the set uses an OUTBOARD crossover, rather than INLINE. An outboard crossover uses both high-pass filters (for the tweet), and low AND high pass filters (for the mids). Some higher end outboard crossovers can include things like variable crossover points and slopes, subsonic filters (eliminating wandering frequencies outside the 20-20kHz range), and thermal overload protection to save your drivers from excess wattage or clipping. So YES, a coax with an outboard crossover will have a better sound than a coax with no outboard crossover. And YES it's soundstage will be better than a component set because the tweet is on the same axis as the mid driver. A MAJOR benefit of these Infinity speakers are the ability to pivot and aim your tweeter, as high frequencies are the most directional of all.
The kappa coax uses the crossover to split the signal into mid and high, but it's final destination is the same: the coax. You'll have to run two speaker leads from the crossover to the coax, one for the mid driver and one for the tweeter.
Oh yeah. :thumbsup:
And furthermore, would it be beneficial (meaning, worth the money) to step up to a component system, like the infinity kappa 680.7cs for the front doors?, and then either of the two coaxials for the back.
If you don't mind the tweeter placement restrictions of the Explorer door panels, I do think you'd greatly enjoy the pleasure of separates up front. They are more aimable (<--is that a word?), can handle more power, and of course, look cooler:D. If you DO put components up front, coaxials will be your best bet for the rear. Rear coaxials provide additional volume while keeping the tweeters are out of the way enough to not interfere with the soundstage at YOUR listening position (the only important position in the truck, as far as I'm concerned). Whatever series you decide to go with up front (kappa, reference, etc) its a good idea to put the same series in the back so the speaker build material and basic sound characteristics will be similar.
The reference components will have a better separation and filtering than the coaxials and will sound much better, yes. As for the comparison between the reference and the kappas, it's like apples and oranges. I like oranges. You may like apples. The sound from each series will differ because of speaker characteristics and build materials. Expect the Reference to have softer sounding highs because of its silk-dome tweeters as opposed to the kappas metal tweeter. The kappas will have better separation and less coloration than the references due to the stiffer midbass cone and steeper crossover slopes (the 6807cs has a the best crossover of the aforementioned). Of the two series, statistically, the kappas are much better (higher wattage rating, higher sensitivity, wider freq. response, better crossovers) but some like a soft, mellow sound rather than a crisp, clean sound and for them the reference would be a better choice, especially at mid volume. I highly recommend finding a local dealer of Infinity speakers and listening to each series for yourself to determine which one suits your personal taste the best.
Hoping I Didn't Forget Anything,
~stu
JL Audio cant go wrong with any of their stuff, The ZR series is the best set of speakers iv ever heard, supposedly there is better but the human ear really cant tell the difference.
