Well, it's official! The transmission is rebuilt! For $400 flat, the transmission rebuilder replaced the clutch packs, reverse sun-gear, reverse solenoid, reverse everything except the reverse band. First band, pump gaskets and rubber ect ect...like a master rebuild. He even degreased the tranny.
I have a couple questions that I would love it if somebody added their input!!!***
1: The transmission cooler line has 2 small holes and the entire assembly is rusted. Should I replace?
2: I mentioned that the seal between the transmission and engine block was really leaking tranny fluid. I did not replace the tranny to engine gasket. Should I? Because the tranny rebuilder said he replace the seals that would usually cause it to leak there...
3: The torque converter has burnt crappy trans fluid inside it. Should I dump it all out? Is it unhealthy?
Just for kicks, here is a list of what needs to be done before I'm ready to sell this Explorer:
Headliner needs replacing. (I had gotten one, but messed it up because there was no sunroof...
Fix body damage
Put transmission back in
Replace the main part of leather front seat (got replacement section)
Fix oil pressure gauge
Plug both rear tires
Other small misc things (knobs, buttons, scratches, ect)
Yet again, I wanna thank you all for the help. Any feedback is appreciated to above questions.
