cmccul002
- March 29, 2008
- Ranger 94
Greetings All,
Just acquired an 89 Bronco II 2.9L 4x4 5 speed.
Took it through inspection and failed for brakes.
Tech said front left failed, didnt have enough "Pressure lbs." He said it probably needs to be bled.
Pedal does feel a bit spongy. I checked fluid, it was actually a bit overfull.
Should I just bleed the front left, or all of them?
Is there anything else I need to do, like bleed ABS valve or anything?
Also, after all this searching, it has me second guessing bleeding procedure, should the cap be on the MC or off when bleeding?
