Explorer brake caliper on a Bronco II? | Ford Explorer - Ford Ranger Forums - Serious Explorations
ifergusson
Regina,SK.,Canada
91 Explorer/84 Bronco II
My 84 Bronco II needs front brake hoses.The parts book seems to show 84-85 Bronco II's having a different hose and caliper than later models.I happened to have a caliper off a 93 Explorer that I parted out handy and I mocked it up and it appears to fit fine.Is there any reason that I can't use the Explorer caliper and hose on the Bronco II?I didn't check the top fitting to see if it is compatible but the rest seems like it should work.
rookieshooter
Moderator Emeritus
Martinsburg WV
84 BII "Li'l Samson"
A few years back I used an Ex brake hose which seemed to be the same exact part but with a different part #. Plus the B2 hose cost more.
Not sure about the caliper.
ifergusson
Regina,SK.,Canada
I was searching around some online parts companies, some seem to show 84-85 caliper as unique while others list the same number for all Bronco II's and also the early Explorers so whatever the difference is it can't be too big.It is reassuring that you were able to use the Explorer brake hose,I was able to find some companies that listed the same number for all year Bronco II's but they seemed to have a different number for Explorer hoses so I wasn't sure if the upper fitting was the same.The Explorer I parted out was really low milage so I would like to use the parts if I can.
Jack Flash
Ethel, MS
(3) '88 BII's, '99 Ranger
when I have questions like this, I go to www.rockauto.com . look up the caliper, when the item(s) appear, click on the item number & it gives a general list of interchanges.
appears the Ex caliper will fit the BII
Backwoods "X"
Mt. Sterling, Ky
94 XLT
old thread, yeah, yeah. The brake pads are the same also. ( I love warrenties )
ifergusson
Regina,SK.,Canada
I was working on the Bronco II tonight and the one bleeder screw was plugged up so I just grabbed one off one of the Explorer calipers.My master cylinder crapped out so instead of replacing it with the same thing I decided to use a newer one with the plastic reservoir on top.Everything seemed to fit fine except the newer ones take a bubble fare instead the v style so I had to reflare the lines.
