- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
I was doing some exploratory surgery today and removed the air box, intake and mounting plate.
Look how much room is in the engine compartment without that giant thing!
Cleaned up an old modification I did years ago to the bottom portion of the air box I like to call the "enlarging the drain holes mod". I know there are no drain holes on the sides, but hey. It has passed numerous smog tests in the People's Republic of Kalifornia over the years because they are not easy to see, and I really don't think they change anything. I bet it matches the performance gain with the KKM filter, and I don't have to change it back every two years, or worry about getting a roadside smog inspection by BAR. When I originally did this, I was more concerned with sucking a engine full of H2O as I have seen happen with the stock intake beginning just behind the lower part of the front grille. The holes would keep water from being sucked up into the intake when it's submerged. It would give me at least two more feet of water to drive into, which I ain't doing. The Explorer was also a lot shorter than.
Also need a new intake gasket, which I am sure is a dealer only item.
