91/96 explorer 5.0 | Ford Explorer Forums
91/96 explorer 5.0
robsvo
richmond virginia
91 xlt
Ok here is what I have
91 explorer with 7 inches of lift and 33/14.50/15 tires
91 explorer v6 harness
99 explorer v8 with engine harness
96 explorer v8 computer and engine harness
85 aod rebuilt and adapter for transfer case
I have most of the wiring diagrams that I think I need ( I hope)
have all the colors listed out and what most of the wires go to for each harness.
what I want to know is
1) does the 96 5.0 explorer have the pats key system?
2) do I have to use the 96 5.0 transmission to use the 96 computer?
3) does anyone know if I have to use the complete dash wiring from the 96 or can I just get the obd section?
1.No 96 does not have the PATS key system
2.Use a manual trans computer
3.Not sure on the dash wiring
did they have 5.0 explorers with manual trans.?
no they did not.
Your 96 computer is OBD II and setup to run the 4r70W trans.
You will need a different 5.0L PCM to run the 5 speed/AOD trans or possible computer modifications.
so I take it that the computer looks for a response from the transmission. I was hopeing that I could just leave that out of the harness I was gonna make. I gess maybe I will change my plans and go get stuff for eecIV if I can't figure anything else out. I just wanted to try and run the eecV since I had the eng. haness and computer.
