94expsport
- August 10, 2009
- Cedartown,Ga
- 1991 Explorer Sport 2wd
Well I got the explore up and running great. Now the problem is I cannot figure out why it wont charge the battery. I put a new alt "not reman" a new Battery and have put two new relays Ones the fuel pump Unsure of the other so i replaced it two. I have also cleaned the Battery wires and cut them back past the corrosion and reinstalled. The light does not come on in the dash except when you turn the switch to crank it then it comes on then goes off like it should. I have been working on this thing for a year I finally got the thing to run great and put the new front clip on and I just cannot firgure out why its not chargeing. I have a muti meter and I have checked several items and cannot figure this out all help will be greatly appriciated. Thanks Rodney.
