SoutherM
- April 4, 2011
- Seattle, Washington
- 93 Ranger 4.0
I just picked up a Full Rancho 5000 lift that came off of a 91 ford explorer 4x4.
I plan on putting it on my 93 ford ranger, which hopefully will turn out.
The lift is supposedly a 3 or 4 inch suspension lift that was taken off at the junk yard so i didn't see how it was completely assembled.
Im looking for instillation guide, pdf or anyone who can help.
My lift came with
Front
2 rs 5000 shocks, 5136
coil springs that are 16" or so
The arms that replace an existing arm bolting the lower end of the shock into. that has the brackets to bolt into the frame.
And some form of transmission lift bar that has 3 points of contact.
on one side, the "swivel side" has a bracket with 1782-2 stamped in the bar.
the other two are on one bar with two bolt holes on either side.
I also received two red brackets that i do not know where they go.
rear
rs 5000 - 5185
coil springs that aren't rancho
If anyone knows of this lift or can aid me on instillation that would be very much appreciated.
My lift came with
Front
rear
rs 5000 - 5185
