FIND
- December 27, 2009
- Vermillion, SD
- 99 XLT V8 AWD
Reposted from Stock 91-94
Automatic 4wd 91 Eddie Bower
When shifting into OD on the indicator, the vehicle will barely move, as if the transmission were slipping. Put it into D it takes off right away. If you shift into OD at highway speeds, it shifts into overdrive just fine. Fluid is not burnt and is mostly clear. Someone replaced the transmission with a used unit about 8 months ago, we just picked the truck up last week.
No other issues, throttle cable is just fine.
