91 vacuum lines | Ford Explorer - Ford Ranger Forums - Serious Explorations
91 vacuum lines
umphlett
morganton nc
91 xlt
I recently bought a 1991 Explorer XLT with a 4.0 push rod engine.
There is a vaccum line missing, I have the line to the cruse ****rol, transmission, the air filter housing, the fuel regulator, and the purge canister.
I cant find where the missing line is. What I need to know is where does that line belong. Also, if I pluged off the leak and the engine almost dies. Second, does the 91 exporer with the 4.0 push rod engine have a EGR valve because I cant find one on mine. If it does where is it located.
Any help is appreciated
Thank you
Vanquish502
Kitchener, Ontario
91EB, 91EB, 92XLT
I believe theres a big one (like 1/2" ID) that goes to the brake booster. When that comes off the engine runs poorly.
jgilbs
Naperville, IL(home)/Iowa City, IA(school)
92 Eddie Bauer
What about the line to the PCV valve? If its not there, check the PCV valve (its on the head, almost right below the vacuum tree)
I dont beleive 91s had an EGR. I have a 92 and I dont have one, but my code scanner throws an EGR fault code for some reason.
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
On the '91 there is at least one connection on the octopus that is just capped off.. On my '92 there are 2 (I think '91 should be 2 also.. just not sure)...
The '91 has no EGR.. the PCV connects to its own connection on the side of the upper intake (not the ocotpus).. and the 2 big ones are for brakes and cruise control.. The rest you already mentioned..
~Mark
91Expgeek
San Diego, CA
'91 Explorer
~Mark
And on my 91 4.0L the cap on the octopus was lost - if you can hear a vacuum leak, check the octopus. I simply put a new cap on mine and all was well again.
