- October 26, 2002
- Location
- Houston, Texas
- Houston, Tx
- '91 XLT, '08 F450superdty
The reason why i am going with 4.10 is because I have 3.73 now and my truck runs awesome with that ratio. If i step up to 4.10 i will be able to use overdrive easier. Which means better gas mileage. I am getting about 11mpg in the city and about 13 sometimes 14mpg on the highway right now. The only reason to go any steeper is if i was lacking power which i am not.
Another huge reason i dont want to go any steeper is because i will be swapping my engine to a stroked and blown cobra, '347' When this is done I will have plenty of power for these gears.
The last reason is because the dana 30 already had 4.10 gears saves me money.
As far as my tranny goes... It does not heat up the slightest bit. I have an aluminum aftermarket tranny cooler on it. I just finished coming back from a trip to mammoth and i went through the hills driving untill i need gas. When i stopped at the gas station i was checking things out to make sure everything was ok, and i touched my tranny cooler with the back of my hand. It was not barely even warm to the touch.
The only thing that will hurt a tranny is if the tranny is downshifting and upshifting constantly. If the tranny can remain in drive or overdrive, whatever you are using it wont be hurt. That is why i use overdrive.
I dont think i will put a hub conversion on it. I though about it but for that kind of money i could just get a dana 60. That is my plan anyway when or if i do finally break what i have. I will get a dana 60 with disks for the rear and a dana 40 for the front.
