NOT IF IT IS THE REAR CALIPER!
You must rotate the rear piston while compressing. The caliper tools you can borrow from most auto parts stores will allow you to do that. You rotate the handle while keeping tension on the nut. I think I initially had to use a wrench to gently apply pressure to the nut while rotating the handle.
From the looks of the bend in the handle on the tool I borrowed, either some calipers require more force than mine, or the tool was being used wrong. Mine did not take an excessive amount of force to rotate the handle to retract the piston while gently following it with the nut on the device..
As for the fronts, they are dual pistons and you have to push them back in together. I just used a short piece of thick home show giveaway yard stick to span them and gently pushed them back in with a C clamp.
