911 PLEASE HELP 92 ford explorer load miss | Ford Explorer Forums
Craig Colorado
92 explorer xlt
Ok this is kinda long but I am out of ideas. Went to holy cross trail on the trail it pick up a miss but only under load so when we got back to camp we went to leadville's part store got plugs wires fuel filter and t state and temp sensor because the gauge was doing wierd things. After installing of parts still had a load miss right at 1600 rpm. So when i got it back to the garage I check codes and got a mass air code swap out the mass air,fixed the code but still missed. So I swap out the coil pack for a used one I had still missed check compresstion 130 warm or cold and vac gauge was perfect. I checked fuel presssure and its 38 psi and hold just like it should. So i then put in a o2 sensor and yep still missing under load SO I give up any ideas????????????:confused:
Check for vacuum leaks, especially at the vacuum tree (drivers side by firewall).
That's what I was thinking.
Along with checking vac pressure did you visually check the lines for cracks. This sounds just like a vac leak.
well I fixed it this weekend. I kinda started over I ran omhs on all the plug wires after checking everything again. I had a two bad wires in a brand new set of wire. so replaced the wires with another new set and what do you know it runs great know. Thanks the help
I was thinking wires, but you replaced them, so I thought it had to be something else. I HATE when new parts are bad...
What brand of wires did you use?
Mike
I used napa mid grade wires and went back with the same. Were I live we have only to part stares napa and checker. Checker here suxs. But thanks for all the help
