92 Cranks but won't Start ?? | Ford Explorer Forums
Katmandu
Troy, Ohio
98 Explorer Eddie Bauer
Engine cranks normally, but will NOT start. :mad:
Where do I begin ??? :(
first check to make sure the fule pump is turning on when you turn on the key, that way you know your getting fule. make sure your crank positioning sensor is plugged in.
pull off one of your plug wires and have some one crank it over for you. make sure your getting fire. then let us know from there.
Where would it be located ??
slide under from the front and it will be a small two wire plug that plugs in right under the crank.
