92 Explorer Eddie bauer on 32's - Now 35's | Page 11 | Ford Explorer Forums - Serious Explorations
Love this build, an inspiration to my mostly stock rig.
Aside form the broken bits, did you have any issues with the driveshaft length after lifting it high enough for 35s?
After a move next month I am planning on ordering a superrunner steering kit and a super lift 5.5" to compliment a SOA.
Anything you want to change about your rig or might do differently?
Thanx.. my rear driveshaft was to short after the lift and i needed to order a longer one..
i still wait for it :D
Now i use a Mustang driveshaft spacer just so i can drive it while i wait for my new shaft.:thumbsup:
Get the lift kit with extended radius arms..
I don't know how the superrunner steering kit is.. but the pitman arm that comes with the kit is to short and i will need to order the longer pitman arm from Skyjacker.
How thick was the driveshaft spacer? The ones I'm seeing online are 11/16".
Some pictures for fun:thumbsup:
My driveshaft came today :D:thumbsup:
Some Quick pictures.
I have seen u joints in betther shape :D
Did some dirt roades today.. only got 3 pictures... Explorer is grate! :thumbsup:
your rear springs flex well! cool.
New Radius arm bushings today:thumbsup:
we are both running basically the same set up and i have driveline issues now too what driveline did you order and how much was it?
im trying to see if it would be cheaper just to take it to my local driveshaft shop and have them fix/lengthen mine
