Pyromaniac91
- February 20, 2006
- Hillsboro, OR
- 91 XLT
'Tis a bone stock 92 explorer with a 5 speed. The womans rig. over the past couple months it started having issues.
When you go to start it it will make a loud click and then go dead. By dead I mean the lights shut off, door wont ding, power locks don't work. Totally dead. Sometimes the power will come back the instant the key is released, sometimes it wont come back for an hour, and sometimes its any period in between. I never gave it much thought, mostly cause i was never there for it, and also because it usually came back pretty quick and she was on her way. I did the head gaskets a couple weeks ago, and the first time trying to start afterwards it did the same problem to me. Click, dead. hooked a jump box to it and no problems, fired right up. Started and ran fine for the next few days.
Last week the problem came back, only much more frequent and usually you could not get it started at all. I had the battery tested and it came back fine. I hook a volt meter to it and reads perfect. I figured it could be a starter solenoid so I replaced it. after doing that it started perfectly for me 3 times in a row, but the instant the woman tried, no dice. since then it has not started once, even when I try to jump start it from my diesel. Wiggling the connectors has never done any good.
When the power does come back on, it seems pretty weak. Lights are dim, door ding is slow, etc. There's been a few times that I'll get it to do the rapid click (like a weak battery or connection) but usually its just the click, dead.
I had an issue similar to this on my wheeler explorer a while ago. My fix for that was to re do the entire ground (different point on the frame, different point on the block) along with a new positive cable from battery to starter. After that I had no issues. I pirated the entire cable system from the wheeler and put it on this rig, and it still isn't doing anything for me. Everything is clean and tight. I am completely out of ideas. Anyone? Ideas, thoughts? Need to get it fixed asap cause I'm getting tired of driving her around.
Thanks in advance.
Thanks in advance.
