92 X running rich, no codes. | Ford Explorer Forums
Nedwreck
Kentucky, Y'all!
'93 xlt, '92 4x4
So... I swapped a '95 4.0 OHV into my '92 X. I used all the '92 sensors and do-dads except for the injectors and water temp sensors. Truck is single O2, and I reused the single O2 pipe and sensor.
The injectors in the old motor were black (19 lb/hr.?) and the 95 motor injectors are red top (30 lb/hr.?).
Truck runs GREAT, and will scratch the tires on takeoff at will.
No burnouts, just really good pep and great low/mid RPM torque (which is my favorite power range, hands down). I haven't taken it past ~3700 RPMs, I haven't the need.
33's on 3.73 gears (FYI).
No codes, no errors. I haven't hooked up my reader, but I do have one.
Here's the rub... it runs rich. Not enough to smoke, or kick a code.. just enough to give a little smell from the tail pipe.
Should I swap the old injectors in? Would using the 95 MAF make any difference?
Stock airbox (with a few holes. heh), stock air filter, and "poor boy" upgraded exhaust.
Would prefer to not foul plugs, soot up the O2 sensor, or induce other problems from a rich condition. That and MPG. (I haven't driven it enough to generate MPG figures)
TIA!
yeah i think 94 or 95 the ohm rating or # per hr changed.i'm having no prob with the 93 ploder injectors in my 92 ranger setup.
If I understand right, the color of the top of the injector tells the rating. Almost sounds too simple.
I should add too, that this truck warms up ~fast~. Like within 5 mins. of starting the heater is working! Doesn't seem to overheat though.. so hey.. that's a perk.
Anyway.. out to twiddle with all the vehicles today, it's time to winterize, tune up, and fix oddball stuff!
it is,only the ford motorsport injectors are color coded.the factory ones aren't.ford has a few colors for the same rating in different apps
good info guys thanks....
will check that regulator later today. :thumbsup:
According to my TSB's the red injector that come out in 1993 are deposit resistant injectors (DRI). The bulletin I'm referring to is 93-7-5
