PropellerHead
- April 19, 2008
- Greenville, SC
- 93 XLT
Hi Explorer experts! I'm the original owner of a 93 Explorer, manual trans, with 214k miles. Great truck and has been very reliable with no significant quirks. Until recently.
After a dealer 60,000 mi service (with fuel system cleaning, new clutch and slave cylinder) has developed a very abrupt throttle on/off response. It's most noticable when trying to maintain a steady speed on level road. Very gently easing off the throttle results in a "kerchunk" as all the drive line lash is suddenly taken up transitioning from pulling to compression braking. Very gently adding throttle results in another "kerchunk" as driveline lash is taken out in the other direction.
It's as if the engine RPMs want to drop too fast. I have noted that the symptoms only occur when the engine has warmed enough to get the temp guage into the bracketed range. When the engine is cold, there is no problem and on/off/on throttle respose is very smooth.
'Seems that the problem might be manifesting only when the computer goes into "closed loop" mode.
Not having an opportunity to leave it at the dealership for them to sort out, I've been trying to diagnose this myself.
I've replaced the IAC and TPS with new aftermarket units with no change in symptoms. Bought an OBD1 code reader, and it showed a continuous code 157 (MAF low voltage). So, I pulled the MAF sensor, checked the connectors and cleaned the sensor.
Disconnected the battery to clear the code. Reconnected and drove for a day. Now, when doing the KOER test, it shows a 411 code (can't control RPM) and seems to be unable to drop the RPMs as much as it used to during that test.
The 411 situation may be a second problem. For now, I'm shooting to get the abrupt throttle response cured as it's very hard on the drive line.
Any leads will be greatly appreciated!
