The whole issue to this problem started when I had a shop replace all the seals in the engine almost yrs ago with 278K miles on the truck - I bought this ex new in 93 and wanted to keep it - It now has 320K on it. The main issue in 2010 was coolant that was building up on the drivers side of the engine. The shop in 2010 replaced all gaskets, including the head gaskets and water pump, timing chain, oil pump, hoses etc. However, they did not check the heads, ie pressure test - of all things that should have been on the top of the list with this kind of work . Yesterday I took the heads to a small performance racing shop because they had same day turnaround. The racing shop owner that machined my heads told me the issue probably revolved around the original water pump. He stated that these heads were warped most likely caused by a weakening original water pump over the years. The impellars wear over time and thus do not move the fluid necessary to maintain proper cooling temp. He mentioned you need to watch your water temp gauge also - but as all ex owners know these sensors can be defective when replaced another thing to wathc for. This was a big learning lesson for me. The heads were probably warped in 2010 and the new gaskets could only hold that gap for a short period of time. The head gaskets that were replaced in 2010 actually looked pretty good ! The shop yesterday pressured tested the heads and they were fine, no cracks - but warped !!
Say - I would appreciate any help from the experienced folks here on correctly installing the head gaskets, RTV'ing in the right places, and direct me to any threads, post ?? I don't want to mess up this critical process.
I am putting it back together this afternoon, Southwest Virginia time. Any PMs or posts welcomed. Thanks to all !!
