Unfortunately I got this all taken apart before the Maniak post with help from MrShorty. That is a great write up and will help with reassembly! I noticed your spindle end is much cleaner than mine was. Anyway, I didn't have to use a lock nut wrench, I easily removed it with my fingers. I also do not have a torque wrench and cannot afford one at this time.
1-Do I need to get a lock nut wrench for reassembly?
2-Will it be safe to tighten the nut until the play is gone while the rotor spins freely?
3-If I get new bearings will they come with races I need to install or are they already pressed into the rotor?
4-Do I need to pack the thrust bearing along with the inner and outer wheel bearings?
Thanks for the replies, I would be lost if not for your help!
