93 XLT...8'' Skyjacker | Ford Explorer Forums
93liftedXLT
left coast
92 xlt
Currently delete
I would suggest new leaf springs instead of the add-a-leaf...but it really all comes down to $$. Good luck
-Drew
could you Recommend one?
8'' is a little crazy for TTB. Cut your fenders out a little bit bigger if you want to fit a larger tire. Steering becomes an issue when you get up there in height.
well here is a TTB with skyjacker 8 " with new 6" leafs in the rear on 35's
Id like to come out around that heighth
I wasn't saying it couldn't be done. But why? Steering can't be good at a height like that with inverted Y steering.
yeah try adjusting the camber with that amount of lift... youll have to replace tires like mad...
I know i can fit 35's its not really about tire size, kinda both height/all suspension, and 34,35's
everyone is doing 5.5 susp with 3 "bl , i thought id be diffront at do all 8' ranger kit, since i havent seen it done much...
You haven't seen it done much because it's not really worth it. Drop brackets become a problem then there's too much leverage on them. Steering also becomes and issue.
I was thinkinh of doing exactly what you are doing myself. I was going to drop down the upper spring seat 2.5 inches and then bolt it to the frame. This would give you about a 2 inch lift or so depending on your current spring sag. Then I was going to get some alignment bushings and pray they would get the tires in good alignment.
As for the rear you can check a local shop and have them arch you some spings, or you can find some off a Ranger, I would assume them would work.
Eric
I just bought some 6' skyjacker coils, and brackets, seems like everyone has something negitive to say..
After all it IS your truck.
I bought some Skyjacker springs and brackets. The brackets look very well built, I am really impressed.
Eric
