94 check engine and ABS light comming on | Ford Explorer Forums
94XMike
St. Charles,Il
'94 Eddie Bauer
I've reciently have done the TPS mod to my 1994 X with good results and about a month later my check engine light and my ABS light have been comming on and off almost every time I drive her. The check engine light seems to come on when I doing city driving more than when I on the highway. Anyone think the mod had anything to do with this? I checked the TPS readings to see if they had changed ovtime and they were ok. I'm confused!
-Mike
To solve the CEL problem, you first need to determine the code that is triggering the CEL.
And with a '94, the only thing you need to run the EEC-IV diagnostic tests is a short piece of wire (a paperclip has been known to serve the purpose). The codes are then output as flashes of the CEL. EEC-IV "quick test" (technical term for pulling codes) instructions can be found at www.dalidesign.com/hbook/eectest.html .
