Currency
- September 11, 2009
- Bedford Indiana
- 94 XLT 4x4
I was leaving home a week or so ago and I noticed my brakes were going further down than normal.
Long story short I had to push the peddle to the floor, pretty much, to get it to stop and still stopping was a challenge. I have some brakes but not like it use to be, then they were not the best either.
I researched on here about air in the lines, master cylinder, and the hydraulic control unit (HCU).
Purchased a new master cylinder, bench bleed it, put it on the truck, bleed the brakes.... three times and it is still the same.
So, That leaves me to believe that it has to be air in the HCU which leaves me with more questions than answers.
How does air get into the HCU? The fluid was fine, never really used any. So I cannot understand it.
I know how to bleed air from the HCU with the little adapter thing, but how much does it normally cost to pay a shop to do this? That is if they have the tools. Going shop labor rate in my area is around $55 an hour.
Also, if the HCU is bad would that allow air into the lines?
Last question(s).
Is there anything else that could cause this problem? If so how much will that cost to replace?
Hopefully I will have it fixed soon. Had been out of work for awhile and just got a seasonal job a few weeks ago, last day is Christmas eve. So I have to have a ride.
Just another note, I had been using my mothers car. But either the fuel pump went out of it or it jumped time today while I was going Christmas shopping
I have had really bad luck vehicle wise lately
Edit: Brakes are still the same, almost none at all. Taking off work tomorrow and taking it to a local dealer to have the entire braking system bleed. If that doesn't fix it I will just have to park it for some time and see if my work will let me work in my hometown. If not I have to get someone to take me to and from work, 20 miles plus one way. If they can't work with me than I guess I won't be able to work with them anymore.
*Crosses fingers and hopes these UPS'ers understand*
Last question(s).
