smegun
- April 3, 2013
- florida
- 1994 ford explorer xlt
im stuck I got the retaining clamp and bolt out the synchro I can rotate left or right but I cant get it to rise out the hole ..
im trying at tdc and atdc
p.s
does the lower manifold have to be off looks tight regarding some tutorials want you to start perpendicular then the unit rotates as its going down hence setting the vane on the first MARK on the window before dropping but will it pass with the lower manifold on ??? not prolifically questioning timing but is lower manifold being in place possible ?
excerpts:
Agreed, but just a note: You can't rely on the timing marks alone... You can be at TDC according to the marks, but actually be 360 degrees OFF TDC. You need to make sure you're on the compression stroke, either by visually seeing that the valves are closed, or by using you finger to feel the air being pushed out as CollisionTech mentioned.
p.s
excerpts:
