JakePSD
- March 25, 2010
- Ohio
- 2003 Mercury Mountaineer
I've already replaced the cam synchro in my truck. Went no problem. Finding TDC to do it is even easier than i thought reading on here. All you have to do is just keep spinning the engine until the alignment tool drops in the synchro as it will only go in when everything is positioned to #1 TDC.
However, I'm questioning the part that I'm about to put in my girlfriends mountaineer. When I put my new synchro in my truck, there was no play in the shaft, but the one that I was about to put in her truck had play in it. I sent it back and got another one. Same thing. Not as much play as the original new one, but still definitely has some. I would think that there should be no noticeable play on a brand new part. Am I right? Or is there supposed to be a slight about of end play on the new part and I put the defective one in my truck?
