DeadlySteve
- November 15, 2010
- Council Bluffs, IA
- 94 limited
Hello Everyone!
I want to preface this by saying I understand that a used A4LD transmission is a failure surrounded by a nightmare wrapped in a leaky box filled with problems.
I have a 94 explorer (with 142k miles) that I purchased for next to nothing with a lot of problems. 1 week after purchasing it, the torque converter blew up and trashed the transmission.
I was given another parts explorer for free (with 144k miles) and a functional transmission. I stripped them down to the frames and between the two explorers, I've pieced together an almost flawless 94 explorer that everyone seems to be pretty impressed with for some reason (if that's possible lol).
Anyway... I cleaned out all the trans lines, swapped in the transmission and put in a new torque converter. Drained all the fluid and filled it. Put in a new filter.
This new transmission does work fine... however, if you accelerate slowly; when it goes to shift into 3rd gear, the RPM's jump about 1k for about a second and then it shifts into gear.
If you accelerate faster than normal (how I want to drive... lol) it has no jumps at all.
It drives around fine... no big deal... I'm just curious. I'm currently looking for an M5OD donor explorer to do a manual swap with. I miss having a stick shift!!
I should also note that I don't actually know how most of the transmission works. I'm a DIY / take things apart / read how-to's / type of person. I don't have mechanical knowledge of how half the parts in a vehicle work... but if I can find what needs to be replaced or if you tell me; I can do it every time.
Any help would be VERY appreciated... even if its, "Hey! you're transmission sucks. Find a new one!!" lol
Thank you very much. :-D
