csturner92
- November 22, 2013
- Ballwin, Missouri
- 1994 Ford Explorer EB
I'm inheriting a '94 explorer 4d/4wd Eddie Bauer from a co-worker, but before I can even do anything to it I had to get it running, here is the story.
The explorer has over 200k on it, but it had been running good until about 1.5~2 years ago. It started losing large amounts of oil. I'm talking almost all of the oil in 30 minutes to an hour. Instead of working on his baby, he parked it and never drove it again recently, when I asked if I could have it.
So far all I have discovered is that:
1. Needed a new battery (duh) - DONE
2. Oil leak seems to be coming from left (if you're in the driver seat) valve cover and is pretty bad. Bolts are tight, so I assume it's a gasket as it is coming from between the cover and where it sits.
3. The oil that is on the ground is the color of coffee with too much cream in it.
As far as the valve covers go, I'm going to be pulling them off and inspect them for damage, and changing the gaskets.
The color of the oil worries me, as I think it could be a head gasket issue.
I've decided to take on the task of disassemling the engine down to the heads, and changing every gasket/seal back up to the valve covers.I'm using the Haynes Repair Manual for the truck and following it step by step, unless of course the forum has an easier method.
What I want to know is:
What else should I be checking for when I'm doing this?
The truck has been parked for a long time, through two winters. Should I be concerned about the color of the oil, or can I just write it off as sitting there too long?
What can I use to clean the inside of the valve covers and so on, to remove any gunk that may be in there? I do not have access to a pressure washer, only my own two hands and a lot of time.
Any help would be GREATLY appreciated. This is my first time undertaking a project of this size, and I'm pretty excited to get started.
