94 Ford Explorer. Mass air flow sensor. | Ford Explorer Forums
Podpunk77
Wichita Kansas
1994 XLT
Last Christmas my explorer died on me and it was becasue one of my after market battery cable had come loose on the battery. I fixed it and that is when it started running like it was chugging for air. Nothing super bad just a little bit. I replaced the battery cables, the spark plugs, the air filter and it was getting worse. now I would push the gas and sometime is would go some times it wouldnt almost like I blew a header or 2. I took it to a shop to get it looked at and after $200 they told me it was the Mass Flow Air Sensor. I told them I would replace that my self to save myself another $100+ more. The new MFAS didnt fix anything how ever with it unpluged it runs great except now im only getting about 10-11mpg.
Any one have any ideas on what could be causing this?
Welcome to this forum! I've moved your thread into the stock 91-94 section. Did you originally have a code for a bad mass air flow sensor? Was the new part the correct replacement for the old one? Did you compare both part numbers?
Check for an open vacuum line. They have a habit of blowing off the tree. Also check the line to your brake booster on the fender
