jake122288
- May 17, 2009
- Pleasantville, iowa
- 1994 4-door xlt 4x4
Ok so i just finished my trns swap and got everything put back together after it had to sit for a few months... everything seems to be connected and what should be in working order the only thing off is the passenger side exhaust manifold and the rest of the y-pipe and the rest of the exhaust. (bolts at the flage broke had to pull off exhaust manifold to drill out old bolts) i have the 02 sensors plugged in and tied up over to the side (according to a mechanic friend of mine it would still start but just run lean or rich for the few minutes i was going to see it if it even started and rn knowing it would run rough) would not having the pass side exhaust manifold and o2 sensors not plugged into any exhaust piping be cause to make it not run? and if not where are some other spots i should check? thanks in advance
