miks95
- July 9, 2005
- Winchester Virginia
- 95 xlt
Hello and good morning. Our 95 will not start, there is no sound from the fuel pump, the relay was replaced and that worked for a while, also swapped the other two relays, no go. I get a code 542, tried disconnecting the cannon plug at the back of the tank, but still get the code. I checked the inertia switch, it's clean and tight. Could it still be bad? It appears my problem is in the engine compartment and not the pump - I would like to verify this any ideas? - Thanks
