jmdinn
- May 21, 2004
- Seattle, WA
- '95 XLT
While doing some gentle off-roading last year, I noticed some peculiarities in my 4wd, especially in 4wd low.
1. after driving up and down steep inclines at slow speeds (no more than 8 mph) for a couple miles, I could smell something had been burning. something oil-greese-fluid like, not like burning plastic. especially noticable if I got out and walked around the front end.
2. i almost got stuck in sand! I thought 4wd was supposed to distribute torque AWAY from the slipping wheel?
I had it examined at a couple shops. One told me that after examining the transfer case, my vent (?) needed replacing. The other told me that after a test-drive, everything was tip-top. I've only used the 4wd twice since; both times in the All-Wheel Drive setting on the same day when starting from a stop on a snowy road. It functioned perfectly, but I'm still nervous.
As you can probably tell, I'm a total newbie with off-roading and a rank amateur shade-tree mechanic (with aspirations).
I'm also putting in a rebuilt tranny in a couple weeks. Since it's rebuilt, should I start it with synthetic ATF? She's got 153k miles and her body's solid, so I'd like to put good parts into her.
Thanks for any advice!!
