Jimbodedious
- February 6, 2019
- Iron, Mt
- 96 Ford EXP
Picked up a 96 Exp. OHV Have had and worked on many over the years.
Turns over fairly easy. no start condition. Pump operative, Did a slight Starting fluid spay to check if i wait between cranks and in WOT it will try to hit not well but tries. Cant remember how easy it should turn over when the timing set is broke, it does kinda sound like it. I looked but other posts not the same as my question.
Ideas? Keep in mind it's 20 below and it's outside at the moment. was hooked to a swingerline stand up charger. has a couple hundred though on it though it looks well taken care of.
So how many say timing set? Not doing compression testy until weather hit at least 10 above.
