somebobby1
- November 30, 2008
- Lothair, Montana
- 96 XLT
96 4.0L engine code (X) V6 113,000 mi.
Scanned engine
P1121-throttle positioning sensor inconsistent w/ mass air flow sensor
P0761- shift solenoid C performance/stuck off
P1116- engine coolant temperature sensor out of range
Checked compression on number 1 & 6 cylinders
I did this twice. The first time #6 was 70psi on first try and 25psi on second, #1 was 25psi both times.
I ran the scan first and after I ran the scan I tried starting the engine and it sounded like a normal cranking engine, but didn't start. I tried it a second time and it turned over like all the spark plugs were removed from the engine.
When I ran the compression test, and took out the plugs,the spark plugs were dripping with fuel.
These are the only tests I have done so far.
The 1121 code may have been entered from some idiot (ME) spraying ether through the mass airflow sensor trying to see if it would start.
Any ideas?
Scanned engine
Any ideas?
