Devilmanak
- November 28, 2011
- McCall, ID
- 2000 Excursion, 98 Plorer
Ok, bringing this back from the dead. Plans changed.
Bought a 98 4.0. Taking the engine out, putting it in wife's 97 4.0. Running into wiring issues, the engine harness is different and the harness junction block pins are different in number and configuration. Seems like I need to take engine apart enough to swap engine harnesses? Problem is, the 97 ECU is gone, and I am not sure if the 98 ECU will work, as the 98 has PATS. So correct me if I am wrong, it seems like the only option I have is to swap engine harnesses and buy another 97 ECU?
2nd problem: I am building a long travel prerunner type rig out of the 98, using the 5.0 out of the 96. It will be stripped down, no a/c, and 2wd. Problem I am seeing is that if the 98/97 engine/engine bay harnesses are different, the 98/96 wiring is going to be really wacky. How similar are the engine bay/chassis harnesses between years? It seems the 98 has a lot more wires in the junction block, did Ford keep the majority of "important" wires the same colors and lcoations in the junction blocks?
And this is all over color. The 98 I bought ran great, just needed a t-case, which I had in the 97. Swap cases, wife would have had a great running, nice 98. But the color was wrong, she didn't like the blue, so now engines are being swapped, the 96/97 "easy" 302 swap has turned into a 98/97 engine swap and a 96/98 engine swap, both of which are a pain because of the 98 being so different.
