JTH1972
- June 8, 2010
- Kelowna, BC
- 96 XL V6 4X4
Hey all,
Well, I'm kind of at my wits end on this one. I've posted about this one in the past without much luck so here's the last shot.
Long story... long: I lost the original FOB for the Exp. Now, this one has the factory security, which I thought was an immobilizer, but it's actually just a starter bypass that you need the FOB to activate, and then you can use the key to start the vehicle. I did buy replacement FOB's but for the life of me (and trying a dozen different methods) I can't get it to go into a programming mode to try to get the FOB's to synch to the vehicle (it's not a PATS system so please don't tell me the programming method for that). So if nobody else has had a similar problem and a trick that I haven't tried yet, is there a simple way to bypass the starter bypass? My only other thought is to install a switch inside the cab that runs from the battery to the starter relay and start the vehicle that way.
Thanks
Thanks
