mlclayton
- July 2, 2011
- Oroville, CA
- 92 Mazada Navajo
Okay, I know this question has been asked a 1000 times before, but I'm going to ask it again. I have a 1996 Explorer, and after changing the fluid and filter, changing out the solenoids and the internal harness to the solenoids, I'm still not able to get it to shift into overdrive. Today it did go into overdrive once, but has not did it again. I keep getting the error code that shift solenoid c is stuck, but actually did replace that one with a new one. Where do I go to next? Could it be a bad valve body? Or bad wires in the overdrive button area in the steering column? Also, who makes a drain plug kit for the trans pan? Thank you all in advance for any help you may provide me.
