syn-
- July 27, 2006
- orlando, fl
- 96 xlt - wip
hey everyone, just got done putting in my trans/back in the truck and seem to be having a really bad day with my truck. It has sat for about a month not being turned over (it ran and drove before taking it apart). Though now that I have it all back together I cannot get it to crank or hear it crank. I have done the following: (the battery is a optima yellow top)
- Hooked up jumper cables to the truck and seen 11.8 readout on my capacitor that I have in the trunk area. Though I did not let it get any higher than this and I am unsure if my battery is so dead that it needs to be charged more than that to start.
- Noticed that after I remove the jumper cables the charge starts to fall off and when I look at my capacitor it reads 8.0
- Checked the starter with a test light and there is power to the starter.
- I have also armed and the disarmed my alarm before turning it over.
- I have checked the 50amp fuse in the fender well and it looks good.
- I have tapped/little whack to the starter and no change.
I did use parts cleaner to spray off the ton of build up that happened from the years of being on the truck. the starter does also seem to be the OEM from 96. Any thoughts? I did have a new ignition key cut (as mine was lost by someone other than me). though I was assured by the locksmith I do not have PATS.
